Hey everyone been cruising the forum for a long time but have never posted. So much good info, I waste so much time here.
Just looking for some opinions as building a new engine for my 67 barracuda this winter. The engine I just pulled is good running a stock stroke .030 over 68 340. I m having my closed chamber edelbrock heads (#60779) ported by Hughes to their S3, biggest they go that doesnt include relocating the pushrod tubes (2.08 int valves, full CNC).
When i built the 340 after I broke the original 273, i put a Hughes hydraulic roller in it (HER 4652ALN), approx. 235 duration @ .050 and .576 lift 103 LSA. I tried a couple cams, so I also have a very similar cam (lift/duration) with a 110 LSA I could use. But the engine never had enough cylinder pressure to run to its potential and putting aluminum heads on it didn't help. It went 12.80s @ 106 not bad, but i want low 11s. I switched to tighter LSA to try build some extra cylinder pressure (who hasnt in their youth bought a bottom of the page cam without having the parts to support it), but i decided that if i pull motor to put in higher compression pistons might as well drop in a stroker kit.
Unless I break something, I want this to be the last small block i build for this car. For argument sake lets pretend I have an unlimited budget but I limited to the S3 CNC porting on the edelbrock heads, a hydraulic roller cam, and stock 340 block. I will be getting forged parts. Street/Strip car, drive to the track couple times of year, it has a good rear, good transmission, and real expensive ATI torque converter, pump gas only, and i would like to put the A/C back on it if I can.
SO please everyone voice your opinion. Is 4in stroke kit better than a 4.125 kit? Hughes 426 kit has smaller wrist pins and rod journals, which i like (lighter right)? Should I buy a kit or piece it together? Who is the best place to get it? I beam or H beam rods? Victor Single plane or RPM airgap? How big a carb do you need for these strokers? Do I need to go to 3in exhaust from the 2.5 TTI system i have? Hughes main girdles worth having? What cam profiles are you guys running?
