Heck yeah Del! That's some REAL progress right there!
He's gearing up for the Dart?Brother, I have been following this thread and I got to ask..
Why?
Why?
I only have maybe $5K in the 2WD pickup and it has no limited slip. It is REALLY rust free, the cab is tight and does not leak, and the only dent in the entire rig is a big gouge on the one side of the bed, which could be fixed. I "may" have it painted "single stage" AKA Matco, etc. It is absolutely worthless in winter. It only has about 140K on the clock. I cannot buy an equivalent 4WD for less than 25-35K around here. Anything cheaper has at least 250K and more. I paid 1500 for the V10 donor, and 300 for the "rolling too short frame."Brother, I have been following this thread and I got to ask..
Why?
Thanks. Not having a great deal of money leaves two choices----work or do witihout LOLHe's gearing up for the Dart?
Between all the boats and truck work, he could have built the Dart 3 times and drove across country once in it and built it again. lol
I really am in awe of the dedication Del has when he sets his mind to it.
The 'eck are you located, by the way? I've forgotten or maybe didn't know I thought I had Coeur d Alene in my <<<<<<<side panel but guess notI'm guessing because 2wd sucks when the ice and snow set in for half the year up here. With 4wd, it's a lot easier to get unstuck.
I've wound up with multiple vehicles good and stuck in the most mundane places, usually at the end of my own driveway. Sometimes a bit of sand does it, but more than once it's been a multi hour fight with tractors getting stuck in order to free the car, then using the truck to free the tractor, then the tractor to unstick the truck after. It gets exhausting.
We are gonna havta get together for the heck of it!!I'm in Cda, south of the river, a few miles into the hills.
Hell yeah! Video man, we need video. lolThu Oct 27 about 1PM
Fired up the diesel "in the new chassis" this morning. I had removed the engine mounted pump "bypass plate" and connected the fuel line direct to the filter, then mounted a new FASS down on the frame rail. I did not drain the engine mount filter or anything onwards to the injection pump. This morning I attached an old refrigeration manifold to monitor and bleed the system up to the filter, and jumpered power to the FASS to do so, bled, and got 15psi.
I expected the thing to fire right up. CHRIST It cranked a lot, then sputtered and clanked and smoked to beat hell. It has NOT gotten anything into the intake, I was careful to take care of that.
If finally settled down after a couple minutes, and restarted a couple times "instantly."
Wound it up (on the hoist) to over a hundred MPH no vibrations in the shaft or noise in the transfer case that I can hear
Now the REAL work begins.
