Progress, even if nearly a standstill.........I think I finally got the correct disc coming, this time from RockAuto. These God Damned so called parts stores don't have it and claim "they can't get it." 5 speed is together and sitting on planks on the frame, and as soon as the clutch arrives I'll get that all together. I "may" jig it up first without the clutch to attempt to get the transfer case shifter located and measured for the cab hole. As you can see I now have the cab, once again, hanging on the hoist.
I plan to install the transmission using a simple come-a-long from a cross piece on the hoist arms. Believe it or not, I can install the TF case by hand. Just not "overhead!!!"
I'm not planning on doing anything to the TF case. It spins quietly by hand OK, and the lube looked OK. I've also got the one from the automatic V10 which could be converted if necessary
