This morning I was thinking about V8 engines, and....
A 400 Cid is too much for a small block. I had a 400 in chevy & there was not enough water jackets to accommodate that much cubic in. As the bore got bigger the water jackets get smaller. Back in the day mopar was known for engineering so they new what no one else new.
Yup had bleed holes in the head
Had one in my supperburban..
78 suburban with a 400sbc with a 142 weinand blew the head gaskets and 6lb of boost ....she did run though and adv 14mpg
400 inch Chevy had siamesed bores, no way for coolant to get between the cylinders.
400 plus cubes in a Mopar small block do not present that problem.
Many of the other make displacements started in the 1950s when each Chrysler division had their own V8s in both hemi and poly head configurations. From 241 to 392 ci displacements. As the 1950s were coming to a close there was a need to simplify the offerings so it was settled on the Plymouth poly being the corporate small block (318) and the big block wedge being the corporate big block starting with the 350. When the LA 273 came out it didn't take long for the 318 to get a wedge head and then came the 340 followed by the 360. There never was a need to have all the other displacements and by the time 1974 rolled around there were four V8s (318, 360, 400, 440). Then the big blocks were dropped after 1978. The 318 and 360 served Chrysler well for a lot of years.
All you needed was a 4 inch stroke crank in a Mopar LA block. There was plenty of room, no clearancing of the block was needed.
Not in Ford's case. The 351M and 400 are both large physically for small blocks. They have plenty of water jacket area.
Well, well, Mother Mopar got away with the LA series as it was a 318 Poly Block design.
Incorrect lifter angles for the LA wedge head and millions were made!
Mother Mopar could have done a head re-design on the 318 Poly head but didn't.
But us Poly lovers know the potential in 'iron' Poly heads and are happy to go 402 cubes.
4 inch bore and a 4 inch throw and 500 horsepower is possible.:thumbsup::soapbox::wtf:
They can also be 390 cubes but that sounds like a Ford number to me...:mob:
And the 332, 360, 361, 391, 410 and 428. All FE's.
Had a 352 in a '76 F150 4x4 short bed stepside. 4 speed, 2 spd transfer, & manual locking hubs. Only vehicle I ever bought new. Paid $4750 for it. Sold it in '92. Handled great, too. The one Ford I wish I still had.
Yeah, they were FE based, but Ford called them FT. Ford Truck. That was their medium duty line of engines. They were real similar to the Chrysler industrial and motorhome stuff. Thicker cast blocks and heads. Heavier cranks and rods. They also had completely different intakes, heads and exhaust manifolds that were not interchangeable with the passenger car/light truck stuff. I always thought Ford went crazy with all the different engine families. ...and we haven't even brought up the Ford Super Duty gas engines. They were a family all their own, with absolutely nothing in common with any other family. I still want a 534 Super Duty engine. They pop up from time to time. Those things are HUGE. Their intake manifold is even WIDER than the FE engines, if you can imagine THAT! They also made the world renowned Seamaster Marine 534 that was twin turbo.
Thanks Rusty. Learned something from you again!
Well it ain't cause I'm smart. It's cause I'm stupid enough to have worked on most all those old Ford medium duty engines through the years. LOL The only one I haven't seen yet is the Super Duty gas engine and that's the one I WANT!
Nice when smart people have some humility. FABO needs more of it sometimes.
Maybe because mother didn’t have to go bigger than 360 to outperform the larger displacement competitors?
IMHO.....
Back in the day.......when Chrysler was having it's financial issues, the reason why so few different engine displacements may be because with fewer different sizes, requirements for tooling and machining costs could be kept to a minimum.
Also, ChryCo was the small fry in the in the Big 3 sand box and would rather put the money into places that counted more.....
Why won't it fit in light trucks? The only one I have ever seen was in a C model. It's about the same size as a Cat 3208.
I didn't say it wouldn't. I just said they're BIG. They're bigger than a 460 though and a 460 is pretty tight even in the F series trucks. I'm sure it could be made to physically fit. They are heavy though and that may present more issues. I'd like to find out. lol Yeah, the C cabs were a popular place for them. Fire trucks and such.
Looks like the dry weight for the Super Duty gas engines, the 401, 477 and 534 is around 1032 pounds. Looks like the 460 weight is 720 pounds. That's about the difference of a redneck fat woman.
I think a steel crank in a 360, bored to +60 and trick heads is...
6 litres of Mopar Heaven!
371 cubes is more than enough for grocery getting methinks.
Bet it would see off most 383's and 400's all day long...:mob:
But as we know most 400's and 440's are 512ci and bigger these days.
For me '' less is More ''...:thumbsup:
AKA Hinkles 426 Poly at 550hp...
You say "less is more" and then post a 426 Poly. lol
Just read that SeaMaster Marine engine weighs over 1300#. 534 only turns 3400 rpm @ hp rating in the trucks.
What would you do with it? Tire burning Rat Rod?
Years ago I saw a scaled down V8 gasoline engine at the Sacramento Autorama. It was something like 1/8 scale maybe? The dude actually ran!
This was in 1993 before CNC machining was available. I have a VHS video of it running. It was really cool.
