earthmover
in the tire smoke
maybe i'm thinking on this a little to much but would it be possible to or would it work???
place car on jack stands remove everything except spindle ,now muck damn sure the wheels are going forward (pointed)..make a plate out of 1/4 stell that will bolt to the spindle that hangs down under the car,now weld a plate to that and to the frame rail..ok unbolt the spindle from the ball joints and remove and change side..now the plate has not moved only thing moved (in mind ) is the point that the drag link bolts to now its on the front and not the back...so now we move to the rack and mount it in good a tight(close) to the mount point of the spindle and make a bracket instead of heating and bending that will go from the spindle mount to the rack...would this work or is it still gonna give you ackerman/bumpsteer problem???? this is just something im thinking of and have not tried..so i would like some info from those that have build a frontend ..i dont need any info on the alterkation or the cap, or the bondo bob setup just some good old help from those that have done it...was lookin over the soildworks program sofeware and thought about trying it.. but had this in my head for a few days now....also before all the work is to be strted the frame will be cross braced so it will not move in any way cause the kframe will be cut and boxed while or before the spindle work is strated so that we have a good point to mount the rack..thanks also i have a susp. book that im reading and plan to get a few more so i know to read and look so lets hear it guys mike:happy1:
i would like to add im am not just calling the people above out for any reason i think they all have a great produce but im trying to do my own car so its not a kick before anybody even try to shoot that out.....thanks mike
