Yes, with a thin cut off wheel.
And yes when large cuts are needed and cleanliness or accuracy is less important.
Is this a yes to both? I only have a cut off wheel and a torch, but Idk how to use the torch lol
It is. I was trying to be a little cheeky with my answer. “Yes and yes”. The torch (if oxy/acetylene) I would not use. It’s probably overkill for sheetmetal. Plasma yes though. And a cutoff wheel on a grinder is a definite yes.Is this a yes to both? I only have a cut off wheel and a torch, but Idk how to use the torch lol
@72bluNblu what do you use to cut the floor boards? Angle grinder? Plasma cutter?
Everyone does fabrication differently, use what tools materials & skills you have...
End of the day whether you choose a five speed or a six speed you're gonna love it... The fun it brings to driving is a game changer...
In years past both my Challengers were automatics...I swapped out driving duties practically ever time I when for a drive... About a year ago I swapped a five speed into the red one.... Sorry to say, the green one is feeling pretty neglected
I installed a TKO.... A buddy with a Cuda bought the TKO twenty plus years ago for a project... The car went through a lot of upgrades before it ever hit the road the first time... It only got driven about 500 miles... He built a much hotter engine than was the plan when the trans was chosen... He didn't like the ratios with the big horsepower, wanted a closer ratio trans... Bought the TKX & gave me the TKO for my labor in doing the swap....Well plasma cutters are cheap, so I’ll get one. I already have the crossmember so it’s can play with the parts car.
Did you do the tkx then?
