you may want to grind a little off that center link for clearance or shim the motor mount,,,dont need sparks,,,from arking
We figured the fix. First a little dab of silicone over the bare spot. Once dry I'll apply two pieces of shrink tube. I made a tab to hold it tighter to the case. Lastly, I'll take your suggestion and cut the stud down.
