matt030305
Hey FABO,
I was wondering what stall converter I should get for my 408 Stroker build. This will be a mostly street driven car so I need something that can cruise and be fairly street-able.
Here’s the build:
-01 magnum block
-Hughes 360 girdle (w/ARP main studs)
-scat 4340 forged 4.00” crank
-scat 4340 I-beam rods with ARP bolts
-icon forged dish pistons (~10.5 CR with 60cc heads)
-Trickflow 190cc heads (TFS-61417802-C00)
-cometic head gaskets
-Harland sharp 1.6 ratio roller rockers made for magnum blocks (pushrod oiling)
-edelbrock RPM air gap (gasket matched)
-Holley 750cfm with electric choke and vacuum secondaries
Here’s the cam going in it:
Duration at 050 inch Lift:
236 int./242 exh.
Advertised Intake Duration:
286
Advertised Exhaust Duration:
294
Advertised Duration:
286 int./294 exh.
Intake Valve Lift with Factory Rocker Arm Ratio:
0.544 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio:
0.541 in.
0.544 int./0.541 exh.
Lobe Separation (degrees):
110
I have 3.23s in the back but will be upgrading to a more radical gearing. I got 245/60/r14s in the back. I need it to be as streetable as possible since i want to be able to cruise on the highway without burning up my transmission. Thanks
Here’s the build:
-01 magnum block
236 int./242 exh.
286
294
286 int./294 exh.
0.544 in.
0.541 in.
110
