Thank you.......Are these available easily? Expensive?That is NOT a proportioning valve. It's a combination distribution block and brake warning switch, see the electrical terminal? It has a piston inside, and if front or rear pressure drops off dramatically compared to the "opposite end" the differential in pressure forces the piston to one end, activating the switch, and turns on your warning lamp on the dash.
It is NOT necessarily just for a drum brake car. Some had separate metering/ proportioning valves.
Thanks for the link:cheers:
FWIW...when I redid the brakes on my 68, I eliminated this distribution block/safety switch. I was converting the rear to BBP with B body 10 x 2-1/2" drums. The fronts are BBP 73-76 discs. Since I had it all apart anyway, I plumbed in a Line-loc for the future 4 speed and added a cheap Summiit (Wilwood) adjustable proportioning valve.
The front brake line goes from the MC into the Line-loc then into a simple tee with outlets to each front brake. The rear line goes from the MC into the adj prop valve then rearwards to the rear brakes. I no longer have a safety switch which does nothing more than turn on the dash light if it senses a leak in the system. I had to custom bend several lines and ended up having a small leak. How did I know w/o the safety warning light? I stood on the brake pedal and held it. Gradually the pedal started moving toward the floor which told me I had a leak. I found the leak and "fixed" it by turning the fitting tighter. So now, I test it occasionally by doing the same simple test at traffic lights. This may not be a good approach for everyone but I like it simple and the fewer connections, the better.
The picture shows the alum MC and you can just see part of the adj prop valve mounted to an aluminum bracket underneath the MC and the Line-loc on the inner fender. Those are temporary bleeder lines going into the reservoir cause I bled it on the car, not the bench. Excuse the messy wiring, it needs to be re-done.
I placed my adjustable prop valve just inside the rocker panel, in between the rocker and drivers seat so that i can adjust the brake bias on the fly.
Correct. The one shown is not for disc brakes. If you're running factory brakes, you can get a stock one off a donor car. If you're running something custom or you just want a new one, get an adjustable valve.That is NOT a proportioning valve. It's a combination distribution block and brake warning switch, see the electrical terminal? It has a piston inside, and if front or rear pressure drops off dramatically compared to the "opposite end" the differential in pressure forces the piston to one end, activating the switch, and turns on your warning lamp on the dash.
Hi, was wondering what master cylinder you had? I'm in the middle of upgrading to 4 wheels disc and was wondering if you have had luck with this mc thanks......sorry for the hack![]()
