stroked340
Big deal..know a couple of "stock stroke" 360's that would hand either one of those engines its arse on the track
Why would Dave's engine be down 80 hp on the one Hotrod tested? Do you think it is the cam or just a different dyno?
The Westech dyno is the answer. My lawnmower would record 15 hp on their dyno.
Big deal..know a couple of "stock stroke" 360's that would hand either one of those engines its arse on the track![]()
lol I have a 383 that would hand your 360 and stroker it's *** on the track, street wherever you want. big deal that's not what this thread is about.
We saw DYNO numbers on this 383, lets see your 360 numbers. 383 are under appreciated. They can Rev real nice. And I think the BB heads are a better design then a SB.Too bad you live way out there..more then a few guys running 383's around here that THOUGHT that too..they went home early![]()
They put the best production small block chevy head on the 383, why not put a better head than the 906 on the mopar? Like a 915 would have the added advantage of tighter quench.
When I posted , I was waiting for this reply. :cheers:Dyno numbers mean NOTHING..e.t. slips are all that matters..we call 383's "taxicab" motors around here![]()
When Mopar put the 383 together for the Road Runner, the lo rpm torque was so low they tried 3 or 4 torque converters until they found one that would allow the car to squeal the tires.
Now Mr. Dulcich puts in a longer duration cam which will reduce lo end torque even more
and his 383 is producing big block torque numbers,80 more ft. lbs than the Mopar Muscle 383 with a smaller cam.
..Hmmm,something doesn't add up?
Ya see, thats the point, theres always (Someone) something to point and ***** about. Perhaps, he used what he had on hand at the time? Perhaps you would like to donate a set of heads and pay the dyno guy.
Or better yet, build 2 383's yourself and dyno the 2 different heads! Come on now, you got money!
They didn't go into the build much. Just simply live with it. Good Lord man!
The Mopar comes out on top and people still argue and cannot stand it.
How do you guys think that 383 Mopar (actually 394ci due to the 0.060" overbore) would fare against an equally prepped stock bore 396 BB Chevy?
