360 plus 30 with 4 inch crank 6 pack headers 2.5 exhaust street car street gears just a driver What would be a good street plug way back when I use ro use N9Y champs Thanks Webby
I wouldn't put Champion plugs in a lawn mower. I have used nothing but NGK, best plug on the market hands down !
I agree. NGK is the only plug I used in my 2 and 4 cycle dirt bikes over the past 45 years. I just recently switched from Autolite to NGK in the Mopars.I wouldn't put Champion plugs in a lawn mower. I have used nothing but NGK, best plug on the market hands down !
Yep believe what you want to believe and I have stories I could tell but sometimes it’s not worth the time lost.
That's just hogwash. There are only three or four factories in the WORLD that make plugs. From there, they are rebranded and sent to vendors world wide. That means there's a GOOD possibility that whoever makes the NGK plugs you like, also make the Champions you don't. A plug is a plug is a plug. Brand has ZERO to do with it as long as you get the correct fit and heat range for your application. You've learned it WRONG from somebody that learned it WRONG and then taught you WRONG and now you're on here tellin other people WRONG. You're WRONG.
Champions=garbage!!!
As long as you disagree, then we all know I'm right.
..Well you are the FORMER technical editor..
I'm going to throw in E3 spark plugs. And really get this post going. More electrodes better spark.
