With the shape of the chamber, you would have to do some carving to put a bigger intake valve in. There sure can't be much flow on the chamber wall side of the valve. I would call it shrouding.
It'll only be as good as the amount of time you take to do it.
Those are thee most involved casting of cylinder head for the these motors to get in shape to make good power.
Bolt on they are small bump in compression..but take a hit in air flow when compared to the other castings.
Watch the video and compare the as cast with the chamber work and valve job I did.
Both the chamber work and valve job are key to how they turned out to that point.
Your results will vary if you skimp on the detail/valve job.
while holding drill with carbide bits
If you’re really using a drill....... the pessimist in me thinks you’re only going to get so far with that.
How about a pic of what you’re using, and of the burs.
IMO........ most people trying their hand at porting for the first time are over zealous, and bite off too much.
They often discover after they’re about 1/2 way through the job that it’s not glamorous work.
Especially if you’re working with tools not really designed for the task at hand.
Use some trans fluid to help cut faster if need be. I used a Black and Decker drill my Grandpa gave me when I did my first attempt at porting a slant 6. The head flowed 175cfm when I tested it decades later 'I still have the head too' . Good luck.I got access to some new carbide bits and a Milwaukee with like 4 battery packs. As it slows down I swap out and charge the old pack. Don’t have access to a large enough air compressor. Agreed, it definitely isn’t glamorous work, but I did expect to be further along after the time I had invested. Can take pics when I get back to the shop maybe this weekend.
I read some stuff on here one too many times and decided to make this 'yet to be finished' series. Used my phone, so turn it up.Now the secrets come out! Lol. Awesome, appreciate the tip. What do the 302s flow stock? I assume similar to my factory 318 72 heads
I think people do that, a lot. That's fine but admit it at least."A novelty head you're a nerd about" Love it!![]()
You have to get it open that far to get past the wall.I traded a few electric die grinders for my head work other wise I wouldn't have bothered. I'm sure it made a difference but I have nothing to compare it to. I should have had a port flowed so I would at least have some numbers.I think people do that, a lot. That's fine but admit it at least.
I should have also said "or have to" since I've done the 273 1.88/1.50 head over 4.04 318.
Those were the only parts he had.
Any bit helps. What ever you did, I'm sure it helped. Some heads respond well to only the right work... while others '318' respond well to any work.I traded a few electric die grinders for my head work other wise I wouldn't have bothered. I'm sure it made a difference but I have nothing to compare it to. I should have had a port flowed so I would at least have some numbers.
You have probably seen these before. They were a mis matched set of heads. I found a later head and a newer rod bearing on one hole. Something happened along the way> LOLAny bit helps. What ever you did, I'm sure it helped. Some heads respond well to only the right work... while others '318' respond well to any work.
What finally did sink in was after taking molds of some ports I did so I could see the port in 3D and take it in the house with me to study.
I wish I had gotten better pics. I opened them up a good amount. Not sure about % though. They were kind of oblong and I tried my best to make them circular below the seat. On that short side you’re right there was a sharp edge I really had to smooth out. The more time I spent in there the more I understood some of the stuff you guys have been saying. I got them to where I was comfortable with and just asked the machinist to look them over and make sure nothings glaring to him. Your videos and mopar joes were very helpful. Few others that escape me.Open the Bowl at the top near the roof 87% of the valve size then transition smaller towards the valve job call the throat around 89% of the seat.
Get the bowls bigger.
I'll post the next couple videos pretty quick here . Leave no ledges under the ssr and project at the final angle of the valve job.
