Tried to reset my timing over the weekend. Found the vacuum advance hose was split cause its binding on the intake where the timing was set. After removing the cap I turned engine by hand to get rotor pointing to 1 on distributor and engine to TDC. I figured I would rotate the drive gear for the distributor a tooth or two clockwise which would essentially created the space I need for the vaccum hose to not bind on the intake. After doing this and re inserting the distributor the rotor was not far off from where it originally was pointing. I only moved it a tooth clockwise. Should I now move the plug wires one post clockwise? The rotor seemed to be pointing similarly to where it was originally but I have much more clearance for the VA hose. The rotor seemed to be in between posts on the cap. This is so basic yet a problem for my brain to comprehend. The car seems to be running fine but the timing mark seems to not be where it should be. I started getting annoyed and had to stop but I am planning on getting under the hood when I get home today.
