Hmmmm.....Wonder why the Ford guys fill in their ports.Hmmmm welll
When you recharge the AC on your car......the first step is to put it into a vacuum, to boil out the moisture.![]()
Being a smart arss of course.......but there may be some merit to that.
If you use a Holley you have more choices to affect atomization and vaporization than any other carb.
If that was the case Bruce wouldn't have had to build his carb to get the atomization and vaporization he wanted. When I asked Bruce about improving the design of the Holley carb his reply was "Why bother, by the time you fix it you might as well start with a Carter. His argument was for design not brand. He wasn't talking about AFB's
Greg said this:
See its like this.You don’t use cfm for optium power with a Holley carb,but its generally more that you need the cfm for poor performing engines.Its all about the burn,you need to realise that.Its not the afr,but rather the way that the cylinder burns the fuel that the carb puts in.The worse the efficiency of the burn,the more you have to use more cfm if the carby isn’t calibrated correctly.You will have to increase the cfm to obtain volumetric efficiency and then use the heat from the overlap period of the cam together with the opoorly calibrated carby so that the cylinders don’t detonate.If the exhaust is restrictive,then a poorly calibrated carb can work ok,you see this in many forms of motorsport.These engines make all their vaporisation in the compression stroke.This style of engine doenst make power with a well calibrated carb and high manifold vacuum.You have to treat these engines like individual runner designs.If an engine gets a very good burn then you can use 1.2 cfm to get 1 hp. As the efficiency of the burn drops you fall back to using 1.5-1.7 cfm per hp.
So you see there are many ways to run engines but there is only a few ways to have efficient ones.
And this in the Shrinker thread.
we all have to deal with engines that make quite a bit of CO.we tune with holleys etc..
We dont have the luxury of very good droplet control so CO is there and a big part of it is good because its a colder burn.its a safer burn.
Lots to think about in those 2 paragraphs......
