Post your wheel and tire combos.
Front
Wheel Brand: Chrysler
tire size: 205/70/14
Suspension mods: None
Rear
Wheel Brand: Wheel Vintiques
tire size: 235/60/15
Suspension mod:s/s springs and shocks(stock location)
Rims are stock 14 inch, 5 on 4.5 pattern on a 1974 Dart Swinger. Replaced junk rubber with 205 X 70-14 on the front and 225 X 70-14 on the rear. Could have gone bigger on the rear but wasn't sure at the time. Car will be a daily driver once my son turns 16.
1973 Plymouth Scamp
Front
Wheel Brand: American Racing Torq Thrust II’s
Backspacing: 5.75
tire size: 235-45 R17
Suspension mods: Lowered torsion bars
Rear
Wheel Brand: Same as above
Backspacing: 5
tire size: 315-35 R17
Suspension mod: Mini tubed, narrowed B body 8.75 Diff., SS springs
1971 Dodge Demon 340
Front's 14 x 5.5 stock rallyes with Goodyear Polyglas E70 x 14
Rear's 15 x 8 4" sbp 4 5/8 bs rallyes with Polyglas GT G60 x 15
finally !
1966 Plymouth Valiant:
Front
15 x 4 1/2 American Racing Torq Thrust mags
5.60-15 old (bias ply) Uniroyal Gasser style skinny tires
Rear
14 x 7 stock steel rims painted to match the body color
28 x 9.50-14 old (bias ply) M&H Racemaster cheater slicks
All wheels have the 5 on 4 1/2 bolt pattern. I love the old school look!
1970 Dodge Dart Swinger:
Front & Rear
14x6 Mopar SBP Rallye Wheels
P225/70 R14 BF Goodrich T/A tires with raised white letters
66340 Sedan dig this, love your Valiant Btw..
Car: 1966 Dodge Dart 170 Sedan Heater/Radio Delete 273 Four Speed
Front Wheels: 15X4.5 Cragar S/S, (5on4.5 bolt pattern)
Front Tires: 640-15 Firestone Bias Plys
Rear Wheels: 15X7 Road Runner Wheels Painted Black
Rear Tires: L60-15 American Racer's
Suspension Mods: Lifted two inches front Via 340 Auto Bars cranked up a couple of turns, and Custom Made leaf springs in rear that rase the back about two and a half inches.
Spun aluminum Cragar Supertricks taken off Mancini's original Superstock Hemi Dart many years ago. 15 x 10 rear, 15 x 4 front skinnys. Goodyear Eagle 10.5 x 30 x 15 slicks in back and Goodyear Eagle front runners up front.
Car is an old '66 Dodge Dart GT drag car. 273 Four barrel, Slickshift Hemi 4-speed, 8 3/4 with 4.86 and a strange spool.
'73 Dart Swinger 318/904
Front:
14" x 5.5" MoPar Rally
215/70-14 BFG Radial T/A
Suspension Mods = none.
Rear"
15" x 7" Specialty Wheel rebop MoPar Rally
245/60-15 BFG Radial T/A
Suspension Mods = saggy springs
AdamR said:
Lets keep a running list of wheel and tire combo. Its an often asked question.
1971 Dodge Demon
Front
Wheel Brand- Cragar SS
Size- 14 x 6" with 4" BC
Backspacing- 3 1/2"
tire size- 225-70 x 14
Suspension mods- .890" torsion bars
Rear
Size- 15 x 7" with 4" BC
Backspacing- 4 1/8"
tire size- 255-60 x 15
Suspension mods- pinion snubber
With this wheel and tire set up do you have any rub in the wheel wells or fenders if letting the shocks down?
Any modifications on the fenders etc?
Thanks
15x3.5 26 in moroso front runner, mickey thompson wheels 15 x10 with 4.5 bs. w 30x9 hoosier lt.wt. radial some tweaking done to the front of wheelwell the rest is stock.28 in tire works fine wo. tweaking .
why dont img. show up ?
Here are a coupel of pics.showing close up of the tweaking of the front , and the clearance in the rear
[/IMG]
[/IMG]
29.5 x 13.50 M/T on 15x10 w/3" bs Centerlines, Rear narrowed 46" & moved back 1.5". Up front to short 23.5" tall Moroso's on 15x3 Centerlines. Front tires will be about 2" taller in future.:toothy7:
front weld 15" -skinny`s comp engineering 90-10 drag shocks
Rear-Weld 15" 4-1/2 back space
rear suspenion-caltracs-mono leafsprings, Rancho 9000 adjustable shocks
Where did you get the hood? I would like one for my 71 swinger. Thanks
front 17x8 30mm offset 235/35
rear 17x8 no offset 245/45
personally i like the tip less duel exhaust.
Here are a couple pics of it on the ground. I did end up trimming some of the lip in the rear. They weren't rubbing but real close.
In case you missed earlier post they are
Wheel Brand Coys Wheels
Size 17X7
Backspacing 4.5"
tire size 245/45/17
Front
Wheel Brand american muscle bullitts
Size 17x8
Backspacing 5.72"
tire size
Suspension mods fat man spindles QA1 shocks
Rear
Size 17x9
Backspacing 5.72" w/ 3/8 spacer
tire size 275-40-17
Suspension mod custom made 2" drop blocks by me w/QA1 shocks
Finally got the Polyglas on...E70x14 on fronts, G60x15's with 8" rallys on the rear AND Yes they ride like hardened donky Sh*&^...all over the road (Mighigan roads, the worst in N.A.) but they sure look great. Met with the Hot Rod Power Tour yesterday north of Detroit; lots of comments.
