MoparDemon
Well the last car i had them on was my 72 Camaro..i know cheby..it had around 350hp guessing obviously but an educated guess combined with 4.56 gears..it came out of the hole hard. Im sure if you had 500+hp you could melt em but in my case with mild motors they hook great, the Demon has 3.23 sure grip with a 4 speed..gonna keep it that way.I've been debating tires. The 275/60/15 certainly gives a lot of options, some inexpensive tires in that size too, less $ than the bigger rim options. 28" diameter is about right. Likely there is room for wider, but then axle width and backspace become critical.
I'm curious, how much hp and what gears were you running with these tires? I want to go fast but also want to be able to light them up! :burnout:
What gear are you running now.
