Jason Ford
Hello all. I've lurked around here for a while (lots of great info that helped me on my 73 Scamp project - thanks), but I've not been able to find info on my current issue... Timing way to high.
Background, 73 slant car that I transplanted a 78 360 into it. I bought the 360 used, but was "told" it was a fairly recent rebuild with 30 over pistons and a mild cam. Before I installed the engine, I did pull the heads and had those re-worked (it did have 30 over pistons). I also pulled the timing cover to check the chain/timing - everything looked correct and new. I did install a Edelbrock 318/360 intake, 600cfm Edelbrock carb, and a Pertronix billet distributor (stock no mods to springs/etc).
The engine is running in the car, but when I tried to set timing I couldn't see the marks no matter how much I cranked the distributor in either direction (standard light - no adjustment). I set timing by ear, then set the carb up to max vac - about 19 inches. I checked TDC (not with a stop but with a screwdriver in the hole just to see that things were close - they were). Today I picked up an adjustable light. With the engine adjusted by ear - using the dial the marks line up at around 50 degrees. If I crank the disty down to 30 or so, it starts running poorly and pops out the pipes. I'm not getting any starter kickback @ 50, not over heating, so I don't really believe the timing is at 50 initial (oh yes - vac/adv disconnected; idle around 900)... So, were there different covers with different marks through the years? If so - any idea how to identify? Any other ideas? Also - I've tried two balancers - the stock on and a new one from summit, both read the same. Sorry for the long post, and thanks to those who read it!
