Locomotion
It would be cool if someone could photoshop that! I'm to computer illiterate to do it. Otherwise I would have done one with "LOCOMOTION" and some combination of white & fluorescent blue over the black with my Dart Sport.
I believe that the "Don Carlton" on the sides was applied during a previous ownership and freshening by Jeff Johnson who runs Chrysler Classics events and emulates the Dart Sports that Don campaigned independently after Chrysler bowed out. Essentially correct (at least not incorrect) for the time. The car would have eventually looked as it does today because it was destined to be the next official Mopar Missile.
Here are 3 pictures of the wire car as it was originally at Don's Lenoir, NC garage with Don Carlton and Mechanic Clyde Hodges on it. In 2 of the photos, you can see the Dart Sport that Don drove with the Rod Shop sponsor paint scheme. The white house at the top of the hill was Don's dad's house with 2 small buildings beside it. Just on the other side of the center building is where this car was parked when I would ride by to look at it. This is the way it was painted.
The difference of having Don Carlton on the side vs Mopar Missile is simple. Chrysler shut down their Pro Stock program and Don Carlton ended up with the car to race personally. Had Chrysler stayed.....it more than likely would have been the next Missile.
This build was influenced by the wire car....and that is about the extent of it.
Some have already referred to the car as the
HDK Missile....
Now that makes me smile.![]()
Looks like the 400 I got from you in trade (keeping the block only). It had a forged crank
which I may sell (I thought all 400's had cast cranks?).
Plans are tentatively for a 440 Source 470 kit 0.035 over (10.06-1 C.R. w/78cc heads), the
new Trick Flow Specialties CNC Power Port 240 78cc aluminum cylinder heads (avail May 2015),
Comp hydraulic roller cam & lifters .560 lift , Comp or PRW stainless roller rockers,
Performer RPM intake, 900 Holley carb, 440 Source balancer, water pump & housing,
Milodon 7 qt. roadrace oil pan. (subject to change without notice)
Yes, I have read that. Good stuff.John, check this out...........
http://www.forabodiesonly.com/mopar/showthread.php?t=257568
Back in August 2010 I posted a thread with current pics of the "Wire Car" as I found it sitting in a local SoCal restoration shop. I found the thread earlier today but the pics no longer show.
I'll reload the pics from 2010 to this thread after I get home from work today - if I can find them...
Quick update on this project.......with the floor removed, the frame with new floor location is in mock up.
What aluminum panels?....maybe a magnesium colored powder coat on the aluminum panels will work.....
Well, where do you find magnesium sheet and more importantly how do you keep it from catching on fire when you are welding it?
C'mon It's the U.S Air Force, you know.... High tech planes and Sh*t, we get all the cool exotic metals and composite materials to play with. Fire ? that's why I'm Certified.
For the uninitiated....on the Wire Car, all of that "sheet metal" in the interior and
engine compartment is not aluminum. It is magnesium and light as a feather.
That is why it is not shiney.
