Printed circuit pins repair
Pompis
Sweden
Today when I removed the dashboard I managed to break of two pins. :oops:
And I wonder if it can be repaired? If so have anyone of you any ideas?
Would greatly appreciate some input how to repair them. Have one idea to solder the pins back and secure them like this.
use the diagram you have to repair. make sure the nail head is thin. I just use solder w/o nail but I do that with loose ones.
Guys have done this. Go to your hardware store and look for brass brads.
Mine had "most of" the pins broken or loose, so I didn't even repair them. I simply scrapped the copper clean, soldered lead wires to each, and ran a ft or so of wire off to Molex style connectors.
Mine had "most of" the pins broken or loose, so I didn't even repair them. I simply scrapped the copper clean, soldered lead wires to each, and ran a ft or so of wire off to Molex style connectors.[/QUOTE]
X2! I used a soldering iron, not a gun or it will get to hot. And defiantly use rosin type FLUX!!!! or it won't stick. Rosin core solder is good but a little extra flux can really help clean the area to be soldered. Get a little bit of solder on the tip of the iron when the iron is hot, before you go at the printed circuit. This will help transfer heat faster and finish the joint faster so you won't melt the p.c. Never acid core solder or acid flux on electrical. That's for the plumbers. IMO
Larry
CLEAN them best you can. Fortunately, copper is soft and easy to clean
BUY some solder that is specified for electrical / radio / TV work. Radio Shack solder isn't that bad
Also you might go to your local welding store and see if they have a product called "No Corrode". Not sure of the spelling I was unable to Google it. It is a pink past flux, used to be in a tin can. Make CERTAIN if you but a separate flux, it s safe for electrical, and not acidic
Thanks for the tips. Made it as player1up did, sort of. Cleaned it up and used flux to get the paperclip to stick. Became very strong and I reinforced the all the other pins so they not come loose because some of them you could wiggle around. Made all of them with a "barb" so they can't pull out as easy. Not the prettiest soldering but I'm very happy with the outcome and I hope someone else could use this information too.
There isn't a lot of clearance cut into the housing. If the leg of the L touches metal...
I'm not saying is see a problem. It's what I cant see that concerns me.
Good luck with it.
I have to tell you that your soldering does not look that good. You need to get some small tools, even a sharp small screwdriver blade if nothing else, knife, abrasive, pencil eraser, whatever you can come up with that is CLEAN and get the surface oxidation off the board
That joint appears to be what is called a "cold" joint. you DO have to be careful not to overheat the board, as you can separate the foil from the board, but it appears that for that joint you need more heat to "flow" the solder
Also refer to your other thread, where I was referring to repair of the gauge limiter socket. See how those contact fingers are crimped into the board? They may NOT be actually making good contact with the board.
Thanks RedFish for that information. Took it apart again to check the clearance and I became worried so I electric taped over the L end at the backside to protect from grounding. Put some copper grease on the screws that connect with the circuit board for better connection too. Now I think it's done properly.
Do you have a meter? Check continuity from the pin to the surface where the bulb sockets contact. Easier than puting it back in to find your turn sinal indicators don't work.
I also solder lead wires to each, and ran a ft or so of wire off to Molex style connectors.
I've done that exact repair several times. Those boards are pretty well made compared to some that I have worked on (nothing pulls traces up like the circuit boards that All American Scoreboards uses).
I'll tell ya, some of the Motorola Spectratac era receivers is pretty bad.............
Third time's the charm:) Now I have soldered all the pins after checking with the meter and I had two pins that had bad connection. Everything works properly now. Soldered the gauge limiter socket also after your input 67Dart273. The joint was not a cold joint, it was just me that did a ugly joint but I fixed it now. Thanks again for yours help
Good work. Most of the soldering looks correct, with the solder in smooth volcanoes that flows up on the pins. Wash off the flux well. I use GoJo or Lava soap on a toothbrush. At a past company, they washed new circuit boards in a dishwasher to remove flux, so don't be afraid of water. These repairs are easy, and anyone can do them. You should see how people repair modern circuit boards with tiny traces. Possible, but takes much skill and proper equipment.
Photobucket nag screen chumps!
