That truly sucks. So are you officially out of the woods or is there still a chance it comes back towards you?LOTS of horses died or got severely burned....
Hell no. Them days over
Fire is only 5 percent contained, but has moved on. So far.....That truly sucks. So are you officially out of the woods or is there still a chance it comes back towards you?
Skimming through Carl Munroe's book.I know it's either the 61-62 or the 65/66 years. I do know that a 65 pushbutton trans will not work in a 63/64
46 horses dead....At least...Some missing...20 percent contained....
Good to know. I need to find that book.Skimming through Carl Munroe's book.
Shift cable '62-'66
Rear pump '62-'65
Internal Park added and changed Years not given
Slip yoke '66
That's the major changes I see. It wouldn't surprise me if there was some difference in the early ones not mentioned or I didn't see there.
That sucks. Likely to never find some either46 horses dead....At least...Some missing...
Nice car there Chris
That sucks. I think I was outside too long today, my lungs are on fireStill snowing...5" on the ground so far.
Thanks.
It's gonna take a lot of work to get those worthy. Trans needs rebuilt and seeing how there's nobody in this area that understands a simple 727 let alone a pushbutton, means I'll be doing it myself. Should be an interesting learning experience. First step though is giving it a good bath, I may rent a uhaul one day when it's warmer and take it to a heated coin car wash. Get all the mud and **** out from under it. Clean out the entire, which is full of garbage and mostly carpet.
You know,they are quite easy to do,good snap ring pliers a bench to hold it vertical and some threaded rod and a crowfoot puller with a few nuts and bolts to make a compressor. Im not doing mine until spring or into summer (904) but pretty much the same.Thanks.
I do have the figure out what locked the right rear . Had all four wheels turning but when to load it on trailer and it locked up tight. Guessing brake
Chris, I did mine for similar reasons. Besides the Munroe book and the shop manuals, I got some stuff (and advice) from A&A. However Cope seems to be very good too. A&A mostly race oriented. Cope does both race and stock AFIAK. If either of them was closer, I would have brought it to them. It wasnt like I was bucking for the challenge - although its always interesting to learn so I have no regrets.Chris, I would recommend taking it to this guy... He's a mopar guy and helped us get the oldest son's trans fixed...
U-haul the car up there or bring him the trans and let him go through it... He's in north west Indiana...
http://www.coperacingtrans.com/
yeah I need to get a good set of snap ring pliers. I have the trans rebuild book and DVD from when I was gonna rebuild the one from my 74 charger. I'll probably pick up a cheap junk 904/727 to practice on first.You know,they are quite easy to do,good snap ring pliers a bench to hold it vertical and some threaded rod and a crowfoot puller with a few nuts and bolts to make a compressor. Im not doing mine until spring or into summer (904) but pretty much the same.
Brake or break???
As long as they don't have deep ruts, that can actually be better for traction.
Depends on how much they want to rebuild it next spring. I think you're right on the pumps btw. I think I was getting the pump confused with the parking brake on some of the pre 62 727sChris, I did mine for similar reasons. Besides the Munroe book and the shop manuals, I got some stuff (and advice) from A&A. However Cope seems to be very good too. A&A mostly race oriented. Cope does both race and stock AFIAK. If either of them was closer, I would have brought it to them. It wasnt like I was bucking for the challenge - although its always interesting to learn so I have no regrets.
***** fought me all the way but she's home
Trust me. There was more than one thought of why the f did I decide to do this...... againThat's not nice to say about her...![]()
