The weight has to be perfectly spread out or they break under very little load. Can’t just have 3-4 contact points.Good to know![]()
I have 2, 4 wheel "carts" I have made for other projects. Moves engines around easily on one of them. Just have to modify some...Hahaha well a 318 poly broke one of those
Good to know![]()
Yep. I added 2x4s to the harbor freight ones and that fixed the problems. The casters work just fine, just the 1/2 in boards aren’t strong enough.I have 2, 4 wheel "carts" I have made for other projects. Moves engines around easily on one of them. Just have to modify some...
I dissembled the wheels and greased the crap out of them. They turn very nice now...Yep. I added 2x4s to the harbor freight ones and that fixed the problems. The casters work just fine, just the 1/2 in boards aren’t strong enough.
Good thing, or you would suffocateGood thing the air is working today
The power supply just arrived (But not for that router) Lol
Good luck. A 11 year old Triton can be disaster. Hope they have been changed before and a little never seize applied.Im just getting ready to start changing these spark plugs in this 2010 5.4 Ford. Had to run errands this morning....
Yup, Actually I talked to Tooljunkie about them. He told me the big issues were in the earlier ones, like 04-07. This Truck has 200K on it. I did call the customer yesterday, and he told me that I am the one that changed them at 100K. If thats the case, then yes I used antisieze. WE will see soon enough....Good luck. A 11 year old Triton can be disaster. Hope they have been changed before and a little never seize applied.
Yes we will..............Yup, Actually I talked to Tooljunkie about them. He told me the big issues were in the earlier ones, like 04-07. This Truck has 200K on it. I did call the customer yesterday, and he told me that I am the one that changed them at 100K. If thats the case, then yes I used antisieze. WE will see soon enough....
Maybe he is a closet GM guy.I just don't understand how a guy could do a full restoration on a car but not know how to shift his Torqueflite out of park without the column in the car.![]()
My thought....Maybe he is a closet GM guy.
Sending you text message on how I did my hemi install from under the cuda.My thought....
I anti-sieze the screws too. And i barely snug em. Sometimes. I dont like ford pickups. At all.Well, it didnt start out well. Just removing the coil bolts 7mm was a challenge. Of course the one in the rear on the pass side (#4) I think. Tucked way up under. Heads on small screws are rusted and diminished in size. Socket slipping. Pulled #3 coil to gain access, And hit the edge of the bolt with a chisel and hammer to break it loose...Now warming engine and will introduce PB Plaster as I break the plugs all loose....Im sure Frank has seen this happen........
I made a drum with saw chain welded to i for chipping wood. It weighs about 6 lbs and i ran it with a 3 hp electric motor. That thing would eat. Think i used about 6 feet of chain. That was back when i figured making my own wood pellets would be fun. Then i realized it was less work to earn the money and buy the pellets instead of milling my own.Well I bet you could lose a few fingers on kickback with this on a 4"grinder.
Good news. All the plugs broke loose. Now lettin em soak some before removing completely.....I anti-sieze the screws too. And i barely snug em. Sometimes. I dont like ford pickups. At all.
