Yes, with a thin cut off wheel.
And yes when large cuts are needed and cleanliness or accuracy is less important.
Is this a yes to both? I only have a cut off wheel and a torch, but Idk how to use the torch lol
It is. I was trying to be a little cheeky with my answer. “Yes and yes”. The torch (if oxy/acetylene) I would not use. It’s probably overkill for sheetmetal. Plasma yes though. And a cutoff wheel on a grinder is a definite yes.Is this a yes to both? I only have a cut off wheel and a torch, but Idk how to use the torch lol
@72bluNblu what do you use to cut the floor boards? Angle grinder? Plasma cutter?
Everyone does fabrication differently, use what tools materials & skills you have...
End of the day whether you choose a five speed or a six speed you're gonna love it... The fun it brings to driving is a game changer...
In years past both my Challengers were automatics...I swapped out driving duties practically ever time I when for a drive... About a year ago I swapped a five speed into the red one.... Sorry to say, the green one is feeling pretty neglected
I installed a TKO.... A buddy with a Cuda bought the TKO twenty plus years ago for a project... The car went through a lot of upgrades before it ever hit the road the first time... It only got driven about 500 miles... He built a much hotter engine than was the plan when the trans was chosen... He didn't like the ratios with the big horsepower, wanted a closer ratio trans... Bought the TKX & gave me the TKO for my labor in doing the swap....Well plasma cutters are cheap, so I’ll get one. I already have the crossmember so it’s can play with the parts car.
Did you do the tkx then?
the HF air body saw is what's up!Plasma cutters are nice for a lot of jobs, but completely overkill for this job.... I mostly used a Harbor Freight air powered jigsaw....
Nice friend.Bought the TKX & gave me the TKO for my labor in doing the swap....
I bought some parts from Silver State, machined some custom parts & installed a reproduction four speed bubble on my floor... With an E body I didn't need to modify the crossmember, just had to massage the floor some...
The bulk of what I needed to do was add the floor hump..
I dropped it in place, traced around it, removed it, cut 1" inside the line, stitch welded the hump in, then from the bottom trimmed the flange closer to the hump... Then hammer & dollied the edge tight to the hump & stitch welded the bottom.. Finally I seam sealed the whole hump & painted everything to match...
After that a few test fitting, a little hammer work to massage in a little clearance & I was good to go..
Sounds like the A body requires quite bit more work...
