autoxcuda
- Joined
- Apr 6, 2007
- Messages
- 9,520
- Reaction score
- 5,044
4:30 gears with 3800 stall do not seems like a setup that would be using that Edelbrock carb and Offy intake on.
I wouldn't run iron heads unless there was a specific reason for it and if so they would be W2's and a ported set at that, if you have to keep a flat hood then maybe a ported Victor and or an Air Gap but if you will have some kind of scoop or clearance than a Super Victor.....again ported would be much better obviously, I run big carbs on everything I ever have owned but they all are some form of rowdy so as of yet no issues going that route and on my 415" street strip deal I ran a 970 Bigs prepped 4150 that worked quite good, the compression is low but maybe you said you did that because of the iron heads.......but again if you could run an aluminum head and with the right cam pick I think 11 maybe crowding 11.5-1 would be possible with a good tune on pump premium, then at minimum a set of step headers and depending how rowdy you got things maybe a set of 1 7/8's, also in my opinion a converter built off of a dyno sheet from a reputable company will net the biggest gain and or loss if not done correctly too in overall vehicle performance. That would be a start for me if I was doing a larger cubic inch stroker and it sounds like you want and or except some decent power from the package........525 hp should be ridiculously easy and 550-575 type range can be done with minimal effort all things considered.I’m open to some suggestions to help the combo. I know the number sucks. What opinions to change do you recommend?
Also it would be solid roller for me every time on any of my builds since so far they have all been fairly rowdy to a lot of rowdy......not even gonna consider anything elseI’m open to some suggestions to help the combo. I know the number sucks. What opinions to change do you recommend?
You had more compression, better carb, better intake, better headers.......it all adds upThat’s Funky.
For reference My current 340 is .30 over, with cleanup job of 2.02 J heads, at 10.2/1 with comp cams XE285HL in at 109 with 241/247 at .050, Holley 750 DP on top of a stock Eddy airgap and TTI headers. On the dyno after brake-in with over night cool down, and then warm up and 30 minute heat soak made 391 HP and 385 TQ on 91 pump gas. This was done on a known dyno in Portland that runs true to others in the Portland metro..
What headers are they? Did he say? You may be right and I was just going off of everything that he listed in his post that sucked.
I have had friends with Chevy's and Fords that ran those spec converters, 3800 and similiar plus or minus........and they all had 4.10's as me, similiar power and or a touch more at least off their dyno sheets but I had a custom 8" 52-5400 range one done and I ran high 6.60's and low 6.70' and they were all low to mid 7's in the 1/8th.........piss poor useless converter pick is what i'm hanging my hat on.4:30 gears with 3800 stall do not seems like a setup that would be using that Edelbrock carb and Offy intake on.
Those are the three items causing the issue.It's not the cam...
Intake and carb are the issue IMO. Heads would be next on the hit list.
I really wanted to stay with the iron cylinder head. I paid good money to have them ported so they would flow. I am open to any intake suggestion as well as carb suggestions. Cams are very hard to come by I felt lucky to be able to get this camshaft. Open to any and all technical suggestions.
To answer a few questions that have been asked. Timing is set at 36 all in. The headers are Doug’s D453 1 5/8”. The carb is one that the shop has. I am taking a 850 Holley today to try it. I will also be buying an Air Gap intake.
