340 WIW.
mpoole
New Member
alberta, canada
Don’t know if this is the best forum for this question… I have a 340 I want to sell. Cast date is 9-29-71, it has J heads and a 650 Holley carb. I do have the other numbers if required but, my question is, can someone tell me what it’s worth. It’s all original and apart, don’t have any use for it as I don’t have time to work with it. Can I get some advice.
1 to 2 grand and that's if its rebuildable problem is, guys will beat you up over what machine work is needed now if you have already done the machine work and its ready to bolt together value goes up etc. It actually tire kicking cause whoever buys it will tear it down LOL! My opinion is this and I own 2 340s that a running 340 ready to drop in a car 3 grand thats low side. That is because they aren't dime a dozen like 318s etc. then there's the early vs late 340 debate etc. in short they are a rare engine so pick a low number and stick to it. You have to watch, experts will profess its junk but still want it for $300 dollars "scrap price" :)
Thanks, I appreciate your response. When I bought the engine, a very long time ago, it was in running condition and should not be a problem. I just took it apart to clean and ensure there was no problems as it’s been awhile but just have no time to reassemble and I did assume that whoever bought it would just strip it down again so reassembling would be a waste of time, lol.
I also have a 340 with a casting date of 1969. I'll be looking to sell it soon. Just like you, I want to get a fair price and don't want to give it away.
The FBBO forum has a section where you can post thread asking 'What's It Worth?" I wish they had that here too. I see ads where guys list some stuff for WAY higher or lower than what I have seen listed elsewhere so a forum for guidance on pricing would be helpful.
For example, I have a 3.55 3rd member that I'd sell but the last time I sold a 3rd member, it was a 2.76 and I sold it for $100. I figured the 3.55 was worth more given the ratio and several years passing. I figure the 3.55 might be worth $200 but when I posted about it at FBBO, some guys estimated closer to $350. Wow!
Thanks, I will check out that forum.
I had one in pieces and figured "its worth nothing in rusted metal" honestly id break even on it with the money I spent assembling it rebuilt J heads and crank machined etc. machine work really runs the bill up but its also the numbers matching engine to my car so...I guess it was worth it...:)
I should have mentioned that having that type of forum here would be more helpful because the 340 is more of an A body engine. Most of the builds over at FBBO are big blocks. Over here, it is small block engines so the 340 value may register a bit higher.
Yeah, we are all Mopar guys but there are some differences between the A body crowd and the B body guys.
It's not "all original" if it has a 650 holley. By all original I would expect it to have at minimum, the correct TQ, intake, exhaust manifolds, valve covers and oil pan. If any of those items are missing or incorrect, the value drops in my opinion. A good bare 72 STANDARD bore 340 block is worth 300-500 in my area. Your results may vary.
Still looking for an early 69 built 340 with 9B306021 VIN. It's always best to post a VIN when selling an engine, lots of people looking for their original. A 72 model year engine is less worth than a 68-71, but still should be in the $1200-1500 range unless it is the original engine for someone...
probably around 1000~1500 depending on condition and what all you mean by "complete".
When I bought my 71 340 about 8 years ago it was just the short block, forged crank, stock rods and pistons bored .030 I gave i believe $400 for it. I had to have it sent to the machine shop to the tune of another 550 plus another 450 for a nice pair of 202 j heads. The going prices around here are anywhere from 1k for a bare block up 3-4k for complete motor also depending of the year.
I sold a bare standard bore 340 block about 15 years ago for $500.00, don't recall what year it was, maybe a 71 or 72, and a 72 date coded factory intake for $150. I also sold a pair of 67 date coded 'X' heads that needed rebuilding for $500.00 two years ago. If you have a complete engine it should be worth $1500 - $2000 cdn IMHO.
Do you really think a rebuildable core is worth 2 grand ?
It’s a 72 340,,,,
Tommy
2k is high side. 72 isnt really a show stopper it's downfalls are easily corrected. The block heads crank etc. is the meat and potatoes and some love the 72 intake and Thermoquad to include the trapdoor air cleaner. But I know what you are saying... if i bought a 72 in pieces Id build it up to earlier specs. I'm talking street not race motor racing is another realm. IMO if you are racing you aren't quibbling about money much or shouldn't be. Also lets be honest 2k isnt alot of scratch these days Im not insulted by that asking price, that actually weeds out alot of deadbeats and tire kickers IMO. If it was me id ask 2k and lower it if the phone didn't ring etc.
the absolute truth is the OPs engine could be an original running time capsule engine with 40k on it and someone would nitpick it to death to get it cheap....
I agree 2k is high side negotioable Id be looking at the block is it bored can it be bored etc. Crank is it forged can it be turned down etc. a good core that still has meat on the bones etc. a good core is able to withstand 1 rebuild with machine work that means not sending it out and the shop says "its no good pitted needs a sleeve "etc. that to me is no go for the high side price. It is somewhat risky now that these engines are 50 plus years old.
I paid $1100 for a 68 340 a couple years ago. It also came with a trans and a few other parts. Original intake, X heads, original valve covers, .020” over but I’m sure it’ll clean up.
I moved it to Mopar General discussion and edited the title. "What's it worth" threads can turn into a sale thread real easy and that can get your thread taken down.. The fellas are doing a nice job of keeping this one on task. Thanks all.
I sold my running 69 340 .030 over complete non original carb to 340 manifolds. Came with big bolt pattern disc brakes and complete V8 K frame and 727 for 3500$ to my friend nearly 10 years ago. The engine is still sitting at my house, geez sure seem like he wanted it at the time.
I sold my running 69 340 .030 over complete carb to 340 manifolds. Came with big bolt pattern disc brakes and complete V8 K frame and 727 for 3500$ to my friend nearly 10 years ago. The engine is still sitting at my house, geez sure seem like he wanted it at the time.
$350/year storage fees. It's yours again. :rofl:
I think we all agree ball park is over a grand anyway...even for a 72 :)
I would say $1000 would be reasonable for a complete one depending on how you want to build it. For instance, if you are planning on building a stroker, you may only use the block, main caps, timing cover and may be the oil pan. Unless it is broken, it should be sent to the machine shop for full machining. I doubt it is assembly ready even though it is in good shape.
You are right
And it is all relative to where you are on the planet at that time
People in certain areas have extremely good paying jobs and money comes easy
They move down here and pay a half million bucks for a shack
People down here just laugh about it usually
Lol
Tommy
