So if I was to put 1971 340 pistons in my 73 engine that would raise the compression to about 10.3 to 1 with my J heads with the 1.88 valves
you guys all know alot more about this then me. i appreciate all the help. if the only things i change in my 73 340 engine is the pistons and cam to the 1968 specs would i be improving the performance? any idea about what hp and cr i would have while using my stock 70-72 cc heads?
I think the heads are 65cc's from what I found online...
