999yards
"HEY Where the white women at" Boy, I haven't heard that in a long time. Used to yell that when I walked into high school parties. No wonder I never had much luck with the ladies back then. I'm cooler now though.
Turned the engine over with the plug out and I could see it sparking.
A internal defect in that wire? It may have shown some spark, but it's not under compression then. You could try a resistance test on it, but it's easier to just swap the complete wire to another cylinder that the length will work on and see if the miss changes to that cylinder.
Just looking for something that's easy to try...
So you have spark and compression then apparently.
Did you try a different plug in that cyl yet?
It's pretty easy to crack the porcelain on a plug.
(Eddie carb?) plug in the back of it?
Brake booster hose on?
Just throwing possibilities for a back cylinder looking like it never ran.
Strangely, no
Now that the valves are closing, make sure they are actually opening.
If no fuel is getting into the cylinder pull the intake off and check it over for a crack , bad gasket, or something obstructing the passage way.
Just a thought, a while back there was a thread on here that stretched into countless pages with the same issue. It turned out the intake had a crack in it. Strangely enough, I think it was the same cylinder too. I can't find the thread now.
Is it possible yours is cracked or leaking somewhere?
Spark, fuel, compression? You must have a large vacuum leak on that runner.
You never know. When you had it apart and the intake set aside some furry little beast could have built a nest in the passage of the intake. It doesn't take them long to do it.I was just thinking about that earlier. I may turn the engine until the intake valve opens and blow some air in through the carb and see if I can hear or feel anything. If not then I will pull the intake.
loosen all the intake bolts and re torque the intake again.this is a big problem on brand x stuff and they have the same intake layout as mopar.
