Over budget 318 build
I guess each piston has its own demand. Those wiseco pistons end gaps are different then the kB. As far as top ring and second.
I think you’re missing the point. None of this is written in stone. The information is out there to absorb and make intelligent decisions based on. Most importantly, share with your machinist what your intended purpose is for the engine and let him make informed decisions about the machine work he does for you.
And here is the chart from KB for skirt clearance. No way would I run 0015-0020 and hit it with juice.
Maybe I am but not real sure. I posted that chart at the beginning of the thread as well. Just needed some help understanding it. And I’m not sure why your saying .0015-.0020 when the block is .030 over and I’m setting gaps for nitrous. I’ve spoken with my engine builder throughout the machine work (And the direction I wanted to go)which is now done and complete. Now I have the block and am ‘absorbing’ new info with the new challenge ahead by reading and asking opinions of members here willing to help. These guys have done builds like mine before where I haven’t so input is welcomed. Thank you for your input
Crank day!
Ok that chart can be confusing. Here it goes. Skirt clearance is the difference in size between the block and the piston. If the bore is 3.940 (030 over) then the piston should mic 3.938 If you wanted .0020 of skirt clearance. This clearance is finished honed by your machinist and should be different for a nitrous engine vs an N/A engine. I’m saying I wouldn’t run .0020 of skirt clearance on a nitrous engine with KB slugs. I’d want a little more. Rings are another measurement all together. But the same theory applies. More heat (nitrous)=more gap. Make sense now?
So what you’re getting at is that I can’t just point a finger at any line on that list, gap the rings to it and expect the motor to hold just because I gapped the rings to it and followed that specific formula. If that’s what you’re saying than I understand. I just got off the phone with my engine builder and he told me that I could hit this motor with 150 shot and cause no problem. ( with the clearances he machined it to). Assuming everything else ‘I’ do is correct.
Might have hit a snag and wanted to hear your thoughts. The bearings that I have for the rods do not have the notch for oiling like the rod does. Do I notch them or can I just install them? Or buy new ones?
Also I didn’t even catch this until I had 3 pistons installed. The oil notches need to be facing the opposite rod... so is this correct in what it meant?
Some bearings have the oil hole and some don't.
The oil hole on the rod should face the center of the engine or towards the camshaft. They are for splashing oil on the bottom of the cylinders.
I just have an oil slot on the cap. Not on the rod itself. And my picture above of the two rods on the crank is looking down from where the cam would be....
How about my bearings. There’s no notch in them so in conclusion, they will not splash oil to the bottom of the cylinders?
No, those won't. Most aftermarket rods don't have the oil hole any more. Someone figured out it wasn't needed I guess.
those are nice. How do you do that? By hand or with a machine? Can be done at home? Please tell.
I had them done at a local shop that specializes in Mopar cylinder heads. The seats were cut on a Serdi machine and Woody hand polished the chambers and ported the heads. Oh, they milled them .030 to bring the chambers to minimum.
Really? You don’t think it’ll cause any problem?
Should be ok. I don't think I have seen any aftermarket rods with the oil hole. So, there is hundreds of thousands of HP engines out there without the squirt holes in them.
In other news, I know how much force it takes to break a ring now. :( I’ll figure this out one of these days. Ha.
