Show off your small block.
How about some of Mr. Norm's handy work?
1st pic. is the 340 in my '72 Demon, 2nd pic. is a 360 in my '77 W300 Dump truck/plow truck, and last is a 2001 360 Magnum (dressed up like an LA small block) waiting to go in my '71 Dart Swinger.
350/417, ported J heads with 2.02 valves. Molnar rotating assembly, Roller Rockers with the B3 Rocker Geometry Correction, M1 intake, 750 Brawler. 520 hp/541 tq on the dyno. Running 4.10s in the back with a GV overdrive and 4500 stall. Painted with same PPG colors to match the rest of the car.
360 LA installed in my 74 Challenger - a 71 360 with a roller cam, roller rockers, ported 915 heads with 2.02 valves, a Thermoquad and TTI headers. She sounds sweet and runs mid 13's in the quarter...
350/417, ported J heads with 2.02 valves. Molnar rotating assembly, M1 intake, 750 Brawler. 520/541 on the dyno. Running 4.10s in the back with a GV overdrive and 4500 stall. Painted with same PPG colors to match the rest of the car.
very understated, almost a sleeper :thumbsup:
how does the gv o/d affect the 4500 stall convertor? it must still be slipping when the o/d's engaged surely? just curious.
thanks, neil.
thanks, neil.
That convertor has great street manners. It's a "tight" 4500. Lol.
Been running it for 12 years behind 2 different engines. Under normal driving, I really don't notice any stall at all. 2 seasons now since adding the GV and still the same.
This one blowed up. Assembled dirty and incorrectly. Some parts were also not there... It ran real hard for a handful of passes.
Gonna find out at lunch, if there's a rebuild in the future. Lots of stuff got hurt.
I am so sorry this happened. It was a very cool build. Do you plan to post a teardown thread so we can learn what happened?
I powder coated the air cleaner lid and valve covers myself. Please ignore the cleaning cloth. I thought I had a better picture.
408 Magnum, Novi 1500SL, Methanol Injection, Terminator X Max, Coil on Plug, Performabuilt 6-planet, Stage 2 4L60e with 3800 stall lock-up converter, 3.91's, Davis Traction Control and A/C.
820hp on 11 psi with up to 26 psi capable with pulley change. Still working on wiring.
We only found the cap for that rod. My Ritter block needs 2 sleeves, and both TI valves are bent in #1. The entire rotator needs to be replaced. I'm really having second thoughts.
There doesn't seem to be anybody capable and trustworthy to get it back together... in my lifetime.
I'm an orthopedic "nightmare on Elm St", and can't really handle the big parts anymore. I'm now at the mercy of other people's capabilities.
Yikes, that's a serious piece! Impressive !!!!!!!!!! and with A?C. Love it.
Didn't a lot of guys use Best Machine that is/was somewhere in your area? It's been a long time since I've seen any of the folks in your area mention them.
