Mad Dart
Nothing to see Here!
Worked on the car again for about 6 hours. I got all the hard fuel lines bent up, made sure my 1 off fancy hillbilly engineered vent is going to work. The fuel sending unit was hitting the bottom of the tank and the pick up too so clearance'd them both. The only thing I will be using is the sending unit. I will be TIG Welding the stock pick up and the stock return line on both ends so it don't have a chance of leaking.
I thought I had all of the tube nuts and sleeves for the hard line but I was wrong. I had the 12 Tube nuts but....... no tube sleeves so I ordered them. I hope they get here at least by friday so I can keep at it.
