Compression on this one is only 10.2:1 ? Damn......
Double checked the cals....10.437
Still I say DAMN! You make them 360's **** and get!
Update:Finally broke into the tens May 12th, following much work and $$. Best 10.96 at 122.14 MPH with 1.56 short. Backed that up with a 10.97 same MPH next pass. 419 stroker, W2 iron heads, AED 950 Super Mod, Cam motion solid roller .680 lift, 727 rollerized, low gear set, Dynamic vert. 4.30 spool 8-3/4. Best short time dead hook on fresh glue 1.49. Looking for 10.80's and consistent.
71 Duster 360 .030 ...3.58 STROKE
77 block
4340 I beam rods
Ross Flat top pistons
10.437 to 1
Eddy Heads from MCH
MP 590 Cam
Crane 1.6 Rockers
Eddy Victor Intake
Hooker 1 3/4 headers
QFT 950-E85 Carb
MP race electronic with MSD 6al
904 trans with Turbo Action 4400 series converter (5200 rpm flash)
Tranzact of Indy Transbrake
4.56 8 3/4
9 x 29.5 M/T slick
10.65 @ 123.22 with a DA of 2100 feet at Bakersfield Ca
60 1.453
330 4.282
1/8 6.707
mph 100.55
1000 8.833
1/4 10.653
mph 123.22
I can finally add mine here now that I got a few runs in for the first time. All steel pump gas (91 around here) street car through mufflers.
1969 Dart
340/417
11:1 CR
Ported W2 's with 51cc combustion chambers
4" Forged Eagle crank and rods
Victor W2 intake
Holley 950 HP
1-7/8" TTi headers and 3" X pipe
Comp roller 266/272 @ .050 .645 lift
MRL roller lifters
727 w/ 8" 5500 converter by Dynamic
4.10 gears with 28" tall MT ET radials 325/50/15
Triangulated 4 link
First time out had a best of 10.89 @ 123.6 mph with a 1.6+ 60 ft. Hope to get much better 60ft in spring and get closer to mid 10's.
What did your heads flow
I put in a 998 tranny (904) and dropped 3 tens. You can too.
74 dart sport, demon front end, r5p7 358 cubic inch, 3375 with driver, full interior, bench seat fold down rear seat, through the mufflers, 28x12 dot tires, best pass 9.98 @134, runs consistent 10.02-10.05, I run in 10.0 index, went 5.87 1/8th and 9.34 1/4 on 6 second 125 shot of spray. freshened motor now with je nitrous pistons, going to spray 250 for the entire 1/4, hoping to run high 8's, sorry for the huge picture
How is that?
727 trans with adapter plate, k frame needed to be notched but I have since gone tubular k frame, I had to build the headers, crank adapter, motor mounts, its a lot of work and if I had to do it over I would just build a nice big block, but there is a neat factor in having a nascar motor in a street car, it is definitely fun, and the dry sump oiling kicks ***,
cap auto products, qa1 nowSweet set up, looks like it came that way! Whose K frame is that?
Thanks!Nice set up Torkflight! :cheers:
How is that?
