Post your 10 second combo
Hopefully a 10 sec combo
68 valiant post
408 stroker 11:1 forged flat top pistons
w2 race heads ported,polished, cnc flow 315 cfm @.600
racer brown cam .597 composite lifters
pro systems 950 carb wilson 1" spacer 1/2 inch fuel line fuel pump aerospace375 GPH
Indy 360 singl plane manifold ported ,polished to match
2.080 valves
1-7/8 TTI headers, x pipe 3" all the way back
8-3/4 -yukon axles , 391 gear, cheetah reverse manual ,hemi front bands 4500 Stall
tire-15x26 235-60 15 M/T slick
Caltracks ,split mono leaf, ranch 9000 shocks
Do you remember WHICH Rancho 9000 shocks you used? Did they have the springs on them in the rear? Were they adjustable in the front like 90/10 shocks?? Thanks. This is all new to me as I've never tried to "hook" a stock car at the drag strip before. Back when I raced it was a Super Gas Camaro. There were no leaf springs!!! I'm lost..........
Finally got the car out for the first time and ran within 2/100 of what I thought it would. Should pick up 2-3/10’s at our home track once it opens.
1/27/24, 11:45am
The Strip at Las Vegas Motor Speedway
10.82 @ 123.54
(I’ll edit the post with full weather conditions when I get home)
1973 Duster
All steel and glass except for a street weight fiberglass hood
3200# estimated. I’ll update once we weigh the car
408 LA based stroker 12.5:1 CR
Icon forged flat tops
Molnar crank and rods
OTB cnc ported Trick Flow heads
OTB Trick Flow intake
Comp Cams billet solid roller 258/264 @ .050 and .660 lift
Harland Sharp 1.5 roller rockers
Hedman Hustler 1 7/8” with 3.5” collector race headers
Full 3” exhaust with Dynomax Ultra Flo mufflers
Thumper Carbs 850 based (flows 977ish) billet 4150
TF727 with Cope RMVB
PTC 8” 5800 stall
9” with aluminum dropout, Strange lightened billet spool with 4.30 pro gear
Calvert split mono leaf and adjustable shocks
Caltracs
Hoosier 29x10.50w sticks
Renegade 112 plus. Plan on testing with VP110 in a few weeks.
Video of a bye run. You can actually hear the car in this one since there isn’t a car with open headers next to me…. lol
1/27/24, 11:45am
10.82 @ 123.54
1973 Duster
Thunder Carbs 850 based (flows 977ish) billet 4150
PTC 8” 5800 stall
I know there’s more left but not many guys switch from off road racing to drag racing and build a car in less than a year. Yet alone drive 12 hours and run 10’s first time out. Congratulations my friend. Great job.
68 Dart , 3,150 lbs. with driver 410 cubic inch small block : 360 Magnum block , 40 over, 9 1/2 to 1 compression, 4 inch forged stroker crank , 585/595 lift mechanical cam, Moroso 8 qt pan , W2 heads, Victor W2 intake , AED 750 hp , TTI 1 7/8 headers , made 545 hp and 520 tq on dyno on pump gas ,race prepped / rollerized 904 with T/A reverse pattern valve body , CSR shield , T/A cheetah shifter , aluminum deep pan , 4900 stall Ultimate 8 inch converter , Mark Williams spool and axles 4.30 gears / Hoosier drag radials on 10 inch Holeshot wheels , Weld front wheels with M/T tires , fiberglass bumpers, hood and trunk lid , front bench seat ( no rear seat ) , Cal Tracs and mono leafs , mini tubs , aluminum fuel cell, Product Engineering fuel pump with -10 line to front , 8 pt. roll bar , frame connectors , springs moved in , has been 10.94 at 119 mph 1.45 60 ft. thru the mufflers with current motor combo will easily go 10.80s with a little tuning but I run on a throttle stop to run 11.50s for the class I run 11.50s at 115 1.49 60ft. foot braking.. leave at 2,000 shift at 6,500.. car has been 10.40s at 124 with same 360 block and W2 heads at 20 over, 590 lift cam and 11.5 to 1 compression 549 hp / 450 tq on race gas... 10. 70s with an R3 block / Indy 360 -1 head combo at 408 c.i. / 9.8 to 1 compression 527 hp / 502 tq. on pump gas... 10.60s with a 340 at 30 over , W2 heads, 527 lift roller cam , 12 1/2 to 1 compression on race gas ... 11.30s with a 340 with ported " J " heads , 557 lift mech. cam , 9.8 to 1 compression !
Updated time and combo.
4/28/24, 1:30 PM
Renegade Raceway
10.32 @ 128.85 mph
58 degrees
40% humidity
29.99 Barometer
1293 DA
29.51 g/lb
4.6mph headwind
1973 Duster
All steel and glass except for a fiberglass hood, trunk lid and bumpers
3146 lbs with me in the car and 5 gallons of fuel
408 LA based stroker 12.25:1 CR
Hand ported Trick Flow heads with 2.08 intake valves
Port matched Trick Flow intake
HVH Super Sucker 1" tapered combo spacer
K&N 9", 5" tall air cleaner
MSD Pro Billet distributor locked out at 34 degrees
MSD 7AL-3 box
MSD Pro Power HVC coil
Turbo Action 5300 stall 8"
Caltracs
Hoosier 29x10.50w slicks
Footbrake launch with 3600 chip (2-step). Converter flashed at 5500 on the hit, shifted at 6800 with 800rpm drop on shifts.
4/28/24, 1:30 PM
Renegade Raceway
10.32 @ 128.85 mph
58 degrees
40% humidity
29.99 Barometer
1293 DA
29.51 g/lb
4.6mph headwind
1973 Duster
MSD 7AL-3 box
Caltracs
That was fun hanging with you & finally seeing the car...get faster and faster and faster.
Hopefully I'll be posting here shortly as well
With the right converter, exhaust and air cleaner removed, I might be able to crack into the 9's. I have a ton of weight I could pull out of the car as well. Probably a good thing I also run in a class with a 10.0 limit.... lol
With just collector extensions no air filter & brakes that would hold to 4k on the 2 step (or your foot stay on the pedal lol) I would bet money you would have ran 10.00
.30 starts getting pretty hard at that ET. But I’m sure you’ll find it.
Yup, I get it however I picked up 2/10's just from upping my launch RPM from 3000 to 3600. I'm going to try 4000 next time out. Plus it should pick up at least a tenth just going to my home track so that with removing the exhaust and air cleaner, getting the tune right with the right converter for my combo, it should put me right there.... Of course that's on paper and not real world. lol
I believe it 100% it's a good car, Bill is good driver
I don't know about being a good driver. I couldn't cut a light to save my ***! I made 6 passes total all weekend and went red on 5 of them. lol
I had 2 -.002's in the red and 1 -.010 red. Twice, my foot slipped off the brake pedal (me standing on it to hold the car....lol) first one was -.110 red and 2nd was a -.094 red in round 2 of eliminations. Only green I had was a .046 in the 2nd qualifier on Saturday.
That's your old *** brake pedal flexing.
When that's where you want it , you won't be red lighting. Just accept it bro lol
How's thst saying go. If you don't red light now and then your not trying hard enough. Lol I just made that up. Lol but don't feel bad Bill I seem to red light way to much my self. Bill put a transbreak in it then you wouldn't have to worry about your foot slipping off the break pedal. Lol but hey least you was out racing.
