Post your 10 second combo
Almost but not quite.......
My Street/strip '71 Cuda 340>
Weight @the line, approx 3580lbs, all steel car.
Engine:- '71 stock 340 block/pistons/2.02 heads+
DC. .590 solid, Holley Strip Dominator intake+2" open spacer, 850DP
MSD6A, NGK 6's
1.3/4" Hedman Race hdrs.
Around 9.8:1CR
727, fmvb, T/A 4200 stall
Stock 8.3/4", posi, 4.30's
Susp:- Stock L/springs, clamped@front, Long Shocks+snubber
Stock front with std worn shocks
Front runners, 10x28 G/years.
best:- 11.01@122.5 w/150hp N20
In 1986.
Last year the No Problem race I ran my best time of 10.39 at 126 mph. The engine has all stock specs. Its a 340 with stock lift and compression. It runs nhra stock class.
My car currently runs 11.20 with a 1.50 60 ft at 117mph.
Trying to get into 10,s. My engine uses w-2 heads with a .650 roller cam.
Please post your entire engine and car chassis combo.
I am trying to see what area of the car I need to improve.Stroker combos
are welcome as well as stock stroke too.
Please help me attain my goal.
Thanks
Duane:read2:
My Duster runs NHRA stock class and it stock specs. The 340 has stock lift, compression and stock carburator and intake.
What is your engine HP? You are running the exact same Mph likr I have.
Would like to have an idea of my 410 build engine Hp.
It is factory rated a 295. On Dyno it has around 490 hp.with 340 cubic inches. Flat tappet cam with stock lift, stock intake and carburetor.
How much torque are you making?
Update: we ran a 10.01 Wednesday night 1.382 60 ft times with a full tank of gas and a significant head wind, through the mufflers. We were at 10.16 best the last couple trips to the track and I installed a 1 inch blend spacer.The spacer is the only thing I changed. On the first pass which is almost always the slowest it ran a 10.06. That is a tens better than is has ever run with no muffler on a Cool morning. It sure seems to like that spacer. I removed a 3/8 four hole, so maybe it didn’t like that one.
We ran a 9.89 and we're told to slow it down, because we aren't licensed ect to go faster than 10 seconds. We weighted the car down a 100 pounds, but still did 9.96. After tinkering with it to get it to go faster, I am kind of lost now. I guess I will concentrate on my r.t. and making the car more consistent and 10 teens or 10.20. It's a lot cheaper to make it go slower than make it go faster though.
67 Cuda "383" S. H code car. Now with a 440 and good internals. Best ET: 10.58 @ 124, more common runs in the 10.70's. It has a 10.97 pass with two people on board!
What size tire and gears ? Looks like it`s twisting a fair amount !
Nice car !!
ET Street. 325-50-15 "R". Dana 60- 4.10. And yes it looks twisted! A good reason why I do not race this car very much. It is too nice to hammer all the time. but I couldnot resist. I was invited to a free track rental just prior to a race. The track was very sticky!
subframe connectors ? That's the only reason I installed a 6 point cage w/ connectors, I knew it would twist the body if I ever got it hooked up, "which I haven`t!"
727 trans with adapter plate, k frame needed to be notched but I have since gone tubular k frame, I had to build the headers, crank adapter, motor mounts, its a lot of work and if I had to do it over I would just build a nice big block, but there is a neat factor in having a nascar motor in a street car, it is definitely fun, and the dry sump oiling kicks ***,
Where did you find the adapter plate for the transmission
Nick, Good question, but, in the future, it would be good to click on the screen name of the person your trying to reach and see when they were last here when your looking at an old (date wise) post. This is what I found;
"torkflight was last seen: Oct 3, 2016"
It may be possible to get his attention by making use of this symbol, @ and then typing his screen name. It will look like this; @torkflight
This will bring attention to him on his alerts.
I finally tickled the 10s (equivalent) in the 1/8 mile. Best ET two weeks ago with a 6.90@105MPH and a horrible 60'.
Super budget turbo build:
-65 Valiant at about 3200lbs race weight.
-Stock bottom 5.9 Magnum, EQ heads, Victor Jr, Fitech 1200 running E85. Single 69mm eBay turbo at 10psi, 727 with RMVB, 9.5" PTC, 3.23 suregrip, minitubbed with 295/60/15 drag radials.
In process of switching from SB to BB. SB I had ran on alcohol best of 10.54 in 1/4 6.59 1/8 126mph 1.42 60fts 590 cam crane 1.5 rockers Ken Jones 750 carb 4:88 gears. I think bigger on carb would have helped.. Heads Hughes mildly ported iron. I'am just about 62 (nov) On hold myself other things going on. Its slowing my BB upgrade for now. Hopefully be ready by spring or mid summer 2011.
Update got 499 stroker now. (2018 retired) Been running 1/8 mile Best 5.94 115
I just realized I have not updated my times in this thread in like... 4 years....well, here we go....
67 Barracuda
360 block, 410 ci, 10.8:1 compression,
Eagle 4.00 steel crank, Scat I-beams, Diamond pistons, total seal rings (file fit),
ARP main/head studs, Edelbrock heads stage II ported by Ryan J @ Shadydell,
Small street solid roller 248/254 duration w/ .576/.582 lift, Victor, 750 dp on e85,
MO875 rearend housing, 4.10 gears, spool, 35 spline axles, Full Caltrac setup (links/Monos/and their shocks),
727, TA manual valve body, 8” converter, 275/60/15 Hoosier drag radials,
3250-3200 lbs in street trim with 3 inch Dynomax bullets.
Best to date (best 60' was not on the same run as the rest): 1.43 60', 6.67 @ 102.1 in the 1/8, 10.54 @ 125.6 in the 1/4.
UPDATE:
New motor that I built for my Barracuda:
· 360 block, 4” Scat forged crank, Scat I-beams, Icon forged flat top pistons
· Ported Edelbrocks, 57cc, Hughes solid 264/268 @ 0.050, Howards oil through lifters
· 13:1 compression, “750” e85 carb built by me (could use more, but that is what I have), Victor intake
· 727 w/ manual valve body, 8” converter, 4.10 gear, 3200# Barracuda
First race (1/8th mile) with it ran 6.59 on the brakes (would have been a 6.58) in bad air. Will go faster soon…should get in the 6.4x’s. Driven too and from the track…because I like to be stressed out :p
1972 Dodge Dart.
360 block bored .070 over. 1/2 filled with hard block for strength.
Custom offset ground crank.
6" small journal SBC rods.
Ross custom pistons, 13.8 to 1 compression.
W2 race ported heads with Manley 2.08 int, 1.65 exh valves
K-motion springs.
Competition Cams full roller cam .646 lift.
Competition Cams pushrods.
Norris stainless steel roller rockers.
Victor intake with single Holley 1050 Dominator jetted .99 all 4 corners.
MSD 7AL ignition box, with MSD crank trigger firing MSD distributor.
Hedman Hussler 2" headers.
LT race 727 Torqueflite with Cheetah reverse pattern manual valve body, Turbo Action 4400 converter
Dana 60 with 5.13 Richmond Pro Gear, Strange axles and spool.
Alston Ladder bar rear suspension with Comp Engineering coil over shocks. Stock front suspension with exception steering has been converted to rack & pinion. Unknown front shocks.
Full cage that has previously been certified to 8.50.
Converter has tightened up and isn't flashing to 4400, will address that issue during the off-season. Best ET to date
is a 10.54. Expect to pick up a few tenths when converter is rehabbed.
1972 Dodge Dart.
K-motion springs.
is a 10.54. Expect to pick up a few tenths when converter is rehabbed.View attachment 1715390255
What size slick is on the car? Can we get some more pics of the car too.
32×14×15
I will take more photos at the track this Sunday and post them.
Car was originally built by a gentleman from Long Island and was a big block 9 second car. Still has the parachute mount and actuation cable from those days.
